Pressed Steel Rocker Mods
Posted 31 December 2018 - 11:25 AM
Andy.
Posted 31 December 2018 - 01:33 PM
like this ?
http://www.theminifo...uild/?p=3533065
..as mentioned, they're pretty robust as they are. I've no idea how hard you'd need to be pushing them to warrant the additional stiffness the welds would give (..i imagine (i.e.guess!) it's done to minimise potential for 'bowing' of the two sides under max lift..)
Posted 31 December 2018 - 02:28 PM
Posted 31 December 2018 - 06:07 PM
Unless you are racing or using it for other similar High Reving with huge Aggressive Cam Profiles, no, I wouldn't weld them up. They are quite stout and stronger than they appear. Even for Competition, many ran them as standard as welding only added weight and there was a risk of weakening them.
Despite their appearance, they are the best factory Rocker that was offered.
Be aware that there is Small Bore and Big Bore types. The difference being that the Small Bore types have a Round Rocker Pad / Tip and the Big Bore are Oval.
