Replaced the old hazard switch with a new one, tried to open up the old switch to have a look and I stupidly pop the plastic piece,pins and spring loose. Now I have tried my best to re assemble it , please see attached pictures and please let me know if you had seen the inside before and see I did it wrong, thanks very much.
Hazard Switch Assemble
Posted 31 December 2018 - 06:28 PM
Posted 02 January 2019 - 07:30 PM
Bit hard to see it,s one of them, you could have held the switch a bit better rather than let it go all over the place - I know its a bit too late now - but **** happens
You can try the parts assembled and see without putting it back on the wired connector and see if it works first, - use a multimeter and check the circuit. Make sure it rocks and locks as it would normally do - and makes a circuit
There is a product called Servisol it cleans the internals of switches without having to take them apart, you spray into the switch for about 6 or 7 seconds, and it normally does the job. Very good gear !
It is the old lubrication inside the switch that gets dirty normally and covers the contacts leading to non connectivity
