Just wanted peoples thoughts on what this https://www.trademe....-1890795447.htm would be worth and if you guys had any reason not to believe it’s authenticity.
Edited by Chris.Williams, 01 January 2019 - 09:24 PM.
Posted 01 January 2019 - 09:23 PM
Posted 01 January 2019 - 10:34 PM
I'm not a specialist in any way on early mini's
but it looks unmolested and around the age that is advertised
I tried the engine calculator in guessworks web site , but it didn't work for that number (aus car ?)
wipers look inset which is right , looks like remote gear change (slightly to the left of rod change) , no floor button start visible , but headlight dip on floor
wet suspension , engine bay looks surprisingly oil free for an old car ?
The wheels look right to me ?
definitely not a 90's MPI - looks like a 60's car that has sat for a long time
smarter folk will be along soon - that know the era better than me
Edited by sledgehammer, 01 January 2019 - 10:41 PM.
Posted 01 January 2019 - 11:48 PM
I checked the engine number on mini manias site, does state 998 cooper.I'm not a specialist in any way on early mini's
Posted 02 January 2019 - 02:18 AM
It could mostly be the real thing.
That engine number prefix does belong to both the later 998 Cooper and the 1071 Cooper S Engines, but that one is clearly a small bore.
I see it has been fitted with Cooper S Wheels, Twin Tanks, neither of which the Cooper had as standard though the RH Fuel Tank could be ordered as an option.
I also see the Manifold doesn't appear a Cooper item but I think a Cooper S one. The Air Filter box of course has been replaced with after market filters.
It would be wise to see what front Brakes are on it as many have been retro fitted with S Brakes.
The Instruments appear correct for a Cooper. The Vinyl covered upper and lower Dash Rails are also correct.
Sad to see it in this condition and it would cost a small fortune to put it right. The 998 Cooper (supposedly) isn't as desirable or valuable as the 997 as they have no factory competition history.
Posted 02 January 2019 - 10:02 AM
That certainly needs a bit of work. I see that the upholstery is plain, is that a NZ thing? There is a fresh air heater fitted, but the air hose is missing and the hole blanked off on the bulkhead. Having said that it looks mostly complete otherwise.
You would need to take a closer look and see how much work is actually needed and see if that matches your pocket.
Posted 02 January 2019 - 10:34 AM
Posted 04 January 2019 - 12:08 PM
Buy it and ship it to the UK. By their standards it's only surface rust
Edited by mikal, 04 January 2019 - 12:10 PM.
Posted 04 January 2019 - 05:13 PM
Posted 04 January 2019 - 06:39 PM
Posted 04 January 2019 - 07:40 PM
We could polish that out
