So I removed the new outlet pipe/hose to compare to the original. As you can see in the attached picture they are pretty much identical in length.
I removed the pipe from the filter and tried moving it around to see if I could remove the kink in the hose. Due to the way it bends back on itself though no matter where I put it there was still some degree of a kink in the hose.
I did notice that the replacement part hose seems to be thinner then the original, which might explain why it kinks easier.
Anyway I'm going to tighten everything up and try running the car.
IMG_7332.JPG 57.24K 4 downloads
