Which Coil For Newly Fitted Electronic Ignition Distributor
3 replies to this topic
#1 minitalia1275
minitalia1275
  • 98 posts
  • Local Club: MiniFriendsTorino
Posted 03 January 2019 - 12:19 PM
I have just fitted an electronic ignition distributor to my 1989 mini 998.
I have a spare coil from my 1991 Cooper, should I use the Cooper coil or keep the existing coil on the car?
#2 nicklouse
  • 17,944 posts
Posted 03 January 2019 - 12:24 PM
you need to use the correct one for the dizzy
see
http://www.theminifo...tributor-types/
#3 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 03 January 2019 - 12:25 PM
You need an electronic coil to go with the electronic distributor. if your wiring loom has a ballast resistor wire(pink/white) for coil positive I'd advise to remove this and fit a standard 12v wire.
#4 minitalia1275
minitalia1275
  • 98 posts
Posted 03 January 2019 - 01:08 PM
Ok thanks, I will fit the coil (electronic ignition) from my Cooper.
Edited by minitalia1275, 03 January 2019 - 03:20 PM.
