Identify Cause Of Blackened Bell Housing Inside
5 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 1,910 posts
  • Local Club: Exmoor Minis
Posted 04 January 2019 - 05:21 PM
This is just for my education but here is a pic of the inside of the Bell Housing on an early MG Metro 1275 that I am stripping and rebuilding. What's the cause of the blackened oil grime on the inside?
Need to know for when I rebuild it?
The clean area is where I have wiped it out with some celly thinners.
Edited by JonnyAlpha, 04 January 2019 - 05:21 PM.
#2 Norris73
Norris73
  • 71 posts
Posted 04 January 2019 - 05:26 PM
Had similar on an old 998cc engine I picked up from eBay. Crankshaft oil seal needed replacing. The black oily grim is a mixture of engine oil and clutch dust.
#3 JonnyAlpha
JonnyAlpha
  • 1,910 posts
Posted 04 January 2019 - 06:43 PM
I figured it was leaking oil in from somewhere :-)
It will get new oil seals all around anyway.
#4 cal844
cal844
  • 6,549 posts
  • Local Club: www.scottishmini.net
Posted 04 January 2019 - 07:18 PM
Primary gear oil seal is weeping and mixing with the clutch dust
#5 mk1leg
mk1leg
  • 9,116 posts
Posted 04 January 2019 - 07:19 PM
Primary Gear seal knackered you will need to remove the flywheel to replace this
#6 JonnyAlpha
JonnyAlpha
  • 1,910 posts
Posted 04 January 2019 - 07:40 PM
The engine is split so yes I'll replace the seal when rebuilding - tks
Mini Spares
