Electric Fuel Pumps
10 replies to this topic
#1 Jase
Jase
  • 1,161 posts
Posted 05 January 2019 - 08:54 PM
Anyone have any pictures of twin electric fuel pumps in the boot with twin tanks? Just looking for advice on the setup and the model of pumps used.
#2 Cooperman
  • 23,039 posts
Posted 05 January 2019 - 09:40 PM
I have twin FACET electric pumps, but I mount then under the rear seat base panel inside the sub-frame. The reason I do this is because I don't like the idea of twin fuel pumps with their electrical connections sharing a space with up to 11 gallons of petrol and a big battery. If something came loose in the boot and fractured the tank to pump pipe there would be a lot of petrol swilling about to short out (wheel-brace or jack, for example).
Mine are piped in parallel, with separate switches and fuses for maximum reliability. I have an aluminium cover plate made from 1.2mm thick aluminium which is bolted to the sub-frame edges.
#3 DeadSquare
DeadSquare
  • 2,767 posts
Posted 06 January 2019 - 09:42 AM
I reposition my original single electric pump inside the boot, tucking it, electrical connections first, under the bottom front corner of the tank with a very short fuel connection to the tank.
I also have a well dum dumed 5/8" cupro-nickel pipe through the cant rail that is curved up to end by the wiper motor, through which I pass a plastic fuel pipe.
(When the cant rail was not foam filled, I used to braze the pipe in place.)
#4 nicklouse
  • 17,945 posts
Posted 06 January 2019 - 01:21 PM
why? you only need one pump. if you want two you dont run one each tank you run then both from a T piece and run one at a time the second is just back up.
#5 Jase
Jase
  • 1,161 posts
Posted 06 January 2019 - 01:38 PM
Looking at a backup. Want to get it all plumbed in sooner rather than later.
#6 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 06 January 2019 - 02:26 PM
79579361-B937-41-EC-A9-A4-A6677-C9-F7-E7
3-EA97772-C636-4378-AFA8-0-D24987846-AD.
I have two Facet cube pumps installed, one on each side of the tank.
#7 Jase
Jase
  • 1,161 posts
Posted 06 January 2019 - 04:57 PM
Do you have a drawing of the setup of the twin pumps? Not sure how they connect.
J
#8 DeadSquare
DeadSquare
  • 2,767 posts
Posted 06 January 2019 - 07:10 PM
What is the good of a Mini boot like that ?
There is hardly room for two toothbrushes for a dirty weekend !
#9 Cooperman
  • 23,039 posts
Posted 06 January 2019 - 08:45 PM
J
I don't have a drawing, but I can explain.
I have to have twin tanks as it is a Mk.1 1275 'S' FIA Group 2 rally car. The tanks have a balance pipe which ensures petrol feeds equally from each tank. There is a T-piece at the RH end of the balance pipe and this feeds down to another T-piece which feeds to the two pumps which sit side-by-side under the rear seat base panel just inside the rear sub-frame on the LH side.
From the pump outlets, two fuel pipes feed to a T-piece and from there a short flexible pipe joins to a continuous metal pipe running inside the car right into the engine bay. In the engine bay there is a pressure regulator before the fuel is fed into the twin carbs.
As for wiring, one pump is fed from the ignition switch. The other has a separate feed, via its own fuse to a switch on the navigator's panel with nothing else being fed from it, to the second pump. Each pump has its own earth for reliability.
#10 mk1leg
mk1leg
  • 9,341 posts
Posted 06 January 2019 - 09:00 PM
I fitted my pump to the rear sub
link pipe
#11 Jase
Jase
  • 1,161 posts
Posted 06 January 2019 - 09:29 PM
J
Brilliant, thanks, got it. Aiming to pick the pumps up at Bingley.
