Hi,
I found a previous post relating to front lights not working but rear all OK, it suggested that you check the 'Big' bundle of wires behind the front grill, first of all I checked fuses, switches, bulbs and current all OK,
As I was in the process of changing the headlights anyway, everything was stripped so easy to see all the wires, turned on the side light switch no lights, so I 'juggled' the bundle and lights appeared, did the same with the headlights so now all working.
Now here is the question, it appears that when the headlights are on dipped one side normal and the other main, and when on main its the opposite, I do not know which is the correct one and also how to cure it.
Help need please.
