Automatic Gearbox
9 replies to this topic
#1 mini1955
mini1955
  • Area Managers
  • 547 posts
Posted 10 January 2019 - 07:26 PM
Hi
I need help please  automatic gearbox will not engage  1st or drive ,only whines ?  will engage  second  third  and reverse
 any ideas welcome  please
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 10 January 2019 - 08:41 PM
know i dear - but try chaning the oil and fillter heared it dose wonders .
#3 imack
imack
  • 2,381 posts
Posted 10 January 2019 - 08:50 PM
Might be worth asking here:
http://autominiregister.proboards.com/
#4 mini1955
mini1955
  • Area Managers
  • 547 posts
Posted 10 January 2019 - 08:52 PM
Thanks for reply's
Will check oil
Have been  on auto register  no reply's
#5 imack
imack
  • 2,381 posts
Posted 10 January 2019 - 09:12 PM
Might be worth contacting Guessworks, I think he only deals with manual boxes but he may be able to put you in touch with someone who knows about autos.
http://www.guess-works.com/
#6 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Try an oil and filter change, also double check the selection mechanism adjustment (a bit of a faff but doable)
#7 mini1955
mini1955
  • Area Managers
  • 547 posts
Posted 10 January 2019 - 09:18 PM
thanks will check linkages
#8 MikeRotherham
MikeRotherham
  • 1,030 posts
Posted 11 January 2019 - 06:34 PM
The oil and filter change is a good place to start.
What year is the mini? For the later versions Rover recommended 10w 40 mineral oil.
There is quite a bit of info on the automatic mini website about oil for the automatic gearbox. Quite a few people recommend using oil that is suitable for motor cycles with wet clutches. This is oil with the specification JAPO MA2 and semi synthetic 10w40.
The gearbox does need very regular and frequent oil changes and if these have been neglected in the past this may be the cause of your problems. I hope so!
Edited by MikeRotherham, 11 January 2019 - 06:36 PM.
#9 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 11 January 2019 - 09:59 PM
10/40 will be ok, my mate runs his late auto on 20/50, it runs good and is generally reliable
#10 MikeRotherham
MikeRotherham
  • 1,030 posts
Posted 12 January 2019 - 11:08 AM
Should have added this to my previous post.
Do you know the correct way to check the oil level?
To check the level in your automatic transmission follow the info below..............
1) make sure vehicle is on a level surface
2) run the engine for 1 to 2 mins
3) stop and wait for 1 min
4) then check the dipstick
