Adjusting Valve Clearances
9 replies to this topic
#1 dotmatrix
dotmatrix
  • 441 posts
Posted 11 January 2019 - 07:23 AM
I have been driving a-series engined cars for quite some years and adjusting valves while easy enough often results in that one valve needs adjusting two-three days later as the nut on the adjuster screw has worked it self loose. I change the small adjuster nuts when needed and always tighten them very tight, but even so they work their way loose. this is quite annoying when I have just put in a new rocker cover gasket. what do you do to avoid this?
#2 ryomini
ryomini
  • 583 posts
Posted 11 January 2019 - 07:50 AM
thread lock
#3 dotmatrix
dotmatrix
  • 441 posts
Posted 11 January 2019 - 10:21 AM
thread lock
really?
#4 nicklouse
  • 19,057 posts
Posted 11 January 2019 - 10:23 AM
never had any come loose.
#5 Spider
  • 15,840 posts
Posted 11 January 2019 - 10:58 AM
If too loose or too tight, they can work themselves undone. When that happens in a bigger way - if the cam was ground correctly in the first place and is not worn out - they'll actually cause the adjuster to tighten up, loosing all clearance and if left to go further, won't allow the valve to close.
#6 GraemeC
GraemeC
  • 7,472 posts
Posted 11 January 2019 - 11:39 AM
I wonder if the threads in the rockers and the adjuster screw themselves may be worn?
You shouldn't have an issue with the rocker gasket - you can use the same ones many times if you don't overtighten it.
#7 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 11 January 2019 - 12:15 PM
Or get a silicon one which is definitely reusable
#8 dotmatrix
dotmatrix
  • 441 posts
Posted 11 January 2019 - 01:30 PM
I change the adjuster screws and nuts when the thread is worn out. which it is sometimes.
#9 dotmatrix
dotmatrix
  • 441 posts
Posted 11 January 2019 - 01:32 PM
ok. I have never tried them getting tighter. only looser
#10 Homersimpson
Homersimpson
  • 851 posts
Posted 12 January 2019 - 09:35 AM
I've never had this on any engine ever, I've never seen it either.
Either the nuts aren't tight enough, are too tight and the threads are damaged or there is something wrong with the threads in the rockers.  I would suggest another set of rockets and see whether it keeps happening.
