Hi, just fitting my front to rear brake pipe.
I've routed it under the subframe rather than behind it. I know that isn't the original way, but its acceptable so long as its all secure from what I've read?
Anyway, I've also read that the pipe needs to be coiled where it connects to the rear subframe, to allow a bit of movement.
Is how I've done it correct?
Also, the metal clips on the underside of the floor, are you supposed to be able to close them up using just your hands? I've had trouble with one of them:
It doesn't want to budge. Does anyone have any tips? I even tried gently tapping it with a rubber mallet, but I still couldn't get it to move.
