Defo do the door steps first, something else to add a bit of rigidity to the frame even if you are bracing the car.
Complete Floor Replace Advice!
Best Answer cookie4343 , 13 January 2019 - 09:34 AM
Have a look at Ben o projects at Mill Road garage.Ben has added plenty of pictures. This should be able to help you out with the process.
http://www.theminifo...-isle-of-wight/
Go to the full post
#31
Posted 19 January 2019 - 08:13 PM
#32
Posted 19 January 2019 - 08:34 PM
what's wrong with doing the floor first and then the door steps, so long as the door steps are only cut out after the floor is back in?Defo do the door steps first, something else to add a bit of rigidity to the frame even if you are bracing the car.
#33
Posted 19 January 2019 - 08:37 PM
#34
Posted 19 January 2019 - 09:03 PM
Personally thats where i would start first. Its an original starting point so that dimension should be spot on from the beginning.
Is it the right way?? well for me i would be happier doing that. Remember what you are putting in place is not original material. The presses have seen better days so a small error could only compound things further along.
#35
Posted 20 January 2019 - 02:29 PM
Thanks again guys really appreciate it
#36
Posted 21 January 2019 - 07:41 PM
Do I need to take the rear bins out ?
Does the door step go under the rear quarter ?
Cheers guys sorry for all the questions
#37
#38
Posted 23 January 2019 - 09:50 PM
Thank you ?
#39
Posted 24 January 2019 - 09:45 PM
#40
Posted 24 January 2019 - 10:02 PM
