Screen De-Mist Vents Covered By Top Dash Rail?
Posted 13 January 2019 - 08:20 PM
I've completely taken out my top vinyl rail, no matter how I position it the plastic bits are still covering the vents. It looks like I need to bend the metal flaps back.
Does this sound right? Has anyone else come across this?
Cheers for any help.
Posted 13 January 2019 - 11:35 PM
I'm going have to do the same with mine
my one de-mists like it's being blown by an asthmatic hamster
the pad is back a bit , blocking flow
also the vent pipes can sometimes drop off behind the trim
best of luck
Posted 14 January 2019 - 07:12 AM
Posted 14 January 2019 - 08:59 AM
I hate to say this, but the easiest way to get the top rail into the correct position is to take the screen out. I had to do this (twice) when starting the rebuild of my IJ. You cant get the correct angle for the centre stud to go through the old ashtray hole and clear the bottom of the screen rubber with it all in situ. Bit of a b*gger I know, but its worth it, and not having to bend any metal flaps because its not really these giving the problem.
Posted 14 January 2019 - 10:54 AM
