Edited by JayKay, 14 January 2019 - 01:19 PM.
Rough Running And Burning Smell
Best Answer JayKay , 14 January 2019 - 04:28 PM
Solved. Turns out the new coil I bought is faulty. Go to the full post
Posted 14 January 2019 - 01:17 PM
Posted 14 January 2019 - 01:32 PM
Posted 14 January 2019 - 01:56 PM
moon hoots lad bet ya got a mouse up the exhaust, or dead cat in the engine bay dose happen
Posted 14 January 2019 - 02:00 PM
Posted 14 January 2019 - 04:28 PM Best Answer
Posted 14 January 2019 - 05:02 PM
Happened on me with a faulty coil
Going along the M42 in the middle lane, and the engine died instantly, luckily I got to the hard shoulder.
Not good
Posted 15 January 2019 - 06:25 AM
Posted 15 January 2019 - 10:17 AM
Not good at all! Took the car for an extensive run after that and everything seems perfect again. Funny the coil failed so quickly, maybe I should get one of the sports coils.
We had a new coil(bought on eBay) fail after we fitted a clutch (took the engine out to refresh the engine bay and fix oil leaks on the engine)
Put it all back together, he car was great until we went into 4th gear, no power... We changed everything, coil, distributor carb the lot...
Solved the problem by raiding one from another mini with the same type distributor. Problem solved,
I bought one from a local supplier and all is well
Posted 15 January 2019 - 11:31 AM
I run on the Lucas sports coil and never had any bother. I do have some old Lucas coils in the garage and they are still strong.
Only bother I ever had was with this one on the M42 when it died on me, it was just a non branded item. Few years ago though, back in 1995
