Water Temp Gauge
6 replies to this topic
#1 tone
tone
  • 27 posts
Posted 17 January 2019 - 12:40 PM
hi my temp gauge always goes off the scale changed the gauge its a smiths one changed sender 3 times any ideas. and its not overheating
#2 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 17 January 2019 - 12:45 PM
Replacing it with a capillary clock is the best thing....
http://www.retromini...products_id=222
You will know what the actual temp is then, even with no electrics
#3 tone
tone
  • 27 posts
Posted 17 January 2019 - 12:55 PM
mm looks nice not cheap though
#4 unburntfuelinthemorning
  • 1,914 posts
Posted 17 January 2019 - 04:59 PM
Has the gauge been wired with a direct 12volt supply instead of going through the voltage stabiliser?
#5 Spider
  • 13,900 posts
Posted 17 January 2019 - 06:14 PM
Just to check there isn't a short somewhere, if you disconnect the wire from the sender, does it still read anything?
#6 Cooperman
  • 23,036 posts
Posted 17 January 2019 - 09:07 PM
I had the same problems a few times.
Fit a capillary-type gauge and remove the problem.
The Stewart-Warner one from Mini Spares looks a good price and their stuff is usually fine.
SWG509
#7 tone
tone
  • 27 posts
Posted 18 January 2019 - 01:17 PM
wired thrugh stabaliser fuel gauge fine if disconnected gauge shows nothing
