Help Identifying Year
Posted 19 January 2019 - 08:59 AM
I’m having trouble with it’s year and hope someone can help narrow it down.
Has hydrolastic subframes, but no motor, body tags or number plates.
Here’s some pictures, it’s rust free, only light surface on the floor, very straight body, no dents.
Complete interior etc
Any help would be appreciated.
A32F28CF-83BA-49FA-AFA1-912940FF8E08.jpeg 70.33K 1 downloads
0437826E-9486-4727-963D-B10F38B77609.jpeg 28.23K 0 downloads
A6A59203-A6CC-427B-831D-1D1E14B7B31B.jpeg 40.74K 0 downloads
888A6474-66BC-41F4-B82B-93DABCF46E1D.jpeg 46.65K 0 downloads
53667FEF-9378-46F2-9110-CAB5D2D01011.jpeg 35.63K 0 downloads
EB8CD0FE-E6A6-45D4-BBCE-83AF1755EDE6.jpeg 41.14K 1 downloads
E8474EB0-1ACF-4C41-AF8A-5668D83F0E1B.jpeg 87.52K 1 downloads
D47655FC-A128-4D80-929B-5E4D0D370780.jpeg 37.49K 1 downloads
5E03128D-5B97-40CA-87DB-7E8224782034.jpeg 53.46K 1 downloads
85E128A3-2F8C-4118-AD85-1F7527042479.jpeg 65.2K 2 downloads
Posted 19 January 2019 - 09:20 AM
Posted 19 January 2019 - 09:26 AM
Ok, didn’t know about any of those.... thanksStart with the dates stamped on the wiper motor, the rear lock Assy and the glass codes.
Posted 19 January 2019 - 09:41 AM
The glass codes depends on who made them. So see what the maker is and then google their "name" glass code.
Posted 19 January 2019 - 01:09 PM
Posted 19 January 2019 - 05:24 PM
I'd need to check, but it doesn't appear original trim for a Deluxe, it does appear later.
The 3 Dial Central Cluster also isn't original.
Deluxes were made from 1965 to early 1969. It replaced the Morris 850 and it in turn was replaced by the Mini K. While we did have a Deluxe here, we never had a Super Deluxe.
Have a look at the wiper motor as Nick suggested for starters, the early Deluxes up to somewhere in 67 had Lucas UK Wiper Motors, then they went over to the Australian Lucas. They are completely different in appearance.
All the Lucas Electrical parts, even the Fuse Block, will be date stamped. Have a look at all of them as some will likely have been changed This will give a guide, add around 2 - 5 months to those dates and you'd have an approximate build date.
Posted 20 January 2019 - 06:30 AM
Seeing as the wiper arms park on the drivers side I think that makes it 1968 or earlier (they started the Deluxe in 1965). There might be a number stamped in the firewall, and one on the radiator shroud.
It's definitely had some mods over the years
Posted 20 January 2019 - 09:34 AM
I’ll look into those spots also, thanks!Seeing as the wiper arms park on the drivers side I think that makes it 1968 or earlier (they started the Deluxe in 1965). There might be a number stamped in the firewall, and one on the radiator shroud.
Posted 20 January 2019 - 10:20 AM
The door cards look right for early deluxe, not 100% sure on the seats but I think they may be right as well.
Its definitely had some mods over the years though. Great looking project, have fun.
Posted 21 January 2019 - 03:43 AM
Posted 21 January 2019 - 07:43 AM
Right, it’s a 66. Found it on the side of the fuse box.
no. it is there for not earlier than a 66. you really need a few more date ID parts.
Posted 21 January 2019 - 08:57 AM
I also found the vin tag, which states it was registered as a 1966 Mk1 Morris deluxe in yellow and black.no. it is there for not earlier than a 66. you really need a few more date ID parts.Right, it’s a 66. Found it on the side of the fuse box.
Edited by Chris.Williams, 21 January 2019 - 08:58 AM.
Posted 22 January 2019 - 02:02 AM
Posted 22 January 2019 - 06:07 PM
Yes, Vehicle Identification Number.Is the VIN tag a local one from when it was imported to NZ?
My friend works at the local vehicle testing office, was able to run the number for me.
