Clutch “Shaft” Damaged !
Posted 19 January 2019 - 05:50 PM
Anyone know if this taper end comes off and can you get a replacement or is it part of the crank ?
Posted 19 January 2019 - 06:06 PM
Posted 19 January 2019 - 06:34 PM
Posted 19 January 2019 - 06:41 PM
pictures of the damage is the only way forward.
and no it is not separate.
the fix depends on what it looks like.
Posted 19 January 2019 - 07:59 PM
Scratches mainly but several grooves
Posted 19 January 2019 - 09:36 PM
Look on the bright side.
Despite what an earlier owner has done to your crank, it was working OK.
You can do very little harm, and a bit of good by lapping the flywheel onto the crank using fine valve paste.
To do this, drain the oil, and using suitable blocks, stand the engine on its water-pump and spin the flywheel on the crank by hand.
Posted 19 January 2019 - 09:39 PM
You can still upload images and link to them.Thanks all. Im only on a mobile and i dont know if you can upload photos from it ?
Or find someone who knows about Minis to have a look . But lapping the flywheel to the crank is a good idea to remove raised surfaces from both.
