Budget Rebuild
193 replies to this topic
#181 Wreckitralph1
Wreckitralph1
    Formally known as wreckitralph
  • 127 posts
Posted 29 January 2020 - 06:38 PM
thanks buddy not everyones cup of tea i know but seems a simple strong and proven way to go wheel centre to wheel centre its 300mm to long but as you can see by the pics its very easy to shorten plenty of straight tube with nothing else attached
that engine is an escort  but its going to be  either the redtop vauxhall or an mx5  i actually bought a 1.8 tuned [dot know whats been done tho] mx5 engine and gearbox for 75 quid complete including sports manifold  ect
Edited by Wreckitralph1, 29 January 2020 - 06:49 PM.
#182 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 02 February 2020 - 04:46 PM
also have this little lot  full mazda mx5 running gear
Edited by Wreckitralph1, 02 February 2020 - 04:54 PM.
#183 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 02 February 2020 - 05:29 PM
so the  strut top towers outside to outside are 25 and 1/2 inches
the outriggers  outside to outside edge is 35 and 1/2 inches the space i have to play with inside my box section sills is 1230mm  so width wise it will fly in and i just have to make some wider outriggers by  4 inches a side  couldnt be much easier i will take the chassis and the box section to my mates unit and lay it on his  huge welding table toget it perfect and level stright ect its difficuilt in mu shed due to the flooring thats in there  i will then ratchet the shell and roll th chassis underneath and slowly drop it down  result
#184 Stealth72
Stealth72
  • Just Joined
  • 25 posts
Posted 03 February 2020 - 06:58 PM
This is going to look awesome!!
#185 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 11 February 2020 - 04:40 PM
sorted my front end upgraded subframe kit to bolt to the main frame
Edited by Wreckitralph1, 11 February 2020 - 04:42 PM.
#186 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 18 February 2020 - 06:07 PM
lookin at this as the  rear set up [right hand pic]    to replicate something along these lines [left pic]
i also have the rolling chassis as previously mentioned looking at all options but i should be able to get some garage time next week and i can sort wich way ime going the bits are not eating or drinking sat on the bench and any unused bits can be sold off or go into the other project
Edited by Wreckitralph1, 18 February 2020 - 08:10 PM.
#187 1330RG
1330RG
  • Just Joined
  • 219 posts
Posted 22 February 2020 - 03:50 PM
I LOVE the direction this build is going!
#188 Verderad
Verderad
  • 394 posts
Posted 22 February 2020 - 10:27 PM
There is a lot of work going into this. Keep going at it.   I'm down the road in Porthcawl if you get desperate and need a hand.
#189 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 26 February 2020 - 08:04 PM
i may well take you up on that mate even if its just to stop me hitting it with a sledge hammer lol
#190 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 01 March 2020 - 10:39 PM
so  maybe a slight change of plan ime now using a saab turbo engine with omega box as i think 250 bhp front wheel drive would be awful torque steer wise   and these can be made to give upto 500bhp so i think its the way to go
Edited by Wreckitralph1, 01 March 2020 - 10:41 PM.
#191 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 04 March 2020 - 06:40 PM
not much to report due to work. but did find these on my phone
its progressed a little since these were taken
  so we have the scalloped box section  to allow the  door step panel to sit flat   the step panel it has those  two indentations wich would stop it  otherwise and obviously  we have the 40mm holes along the full length of the box
A,to lighten it and B  it looks cool
everything i do will be tied into these new  pieces  the box section across the front will be going it was just to keep it all square the one at the back is staying as this forms the top of the rear frame for the prop and exhaust tunnel
Edited by Wreckitralph1, 04 March 2020 - 06:50 PM.
#192 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 15 March 2020 - 07:17 PM
found a few more pics i forgot to upload i wont bother with any description suffice to say next time will be pics of the irs wishbones and ford hubs  sierra diff fitted then its new rear quarters and bootfloor fitment
#193 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 02 April 2020 - 03:21 PM
havent done to much as i need to collect parts and with the lockdown atm i cant so decided to get the windscreen surround in place using the bulkhead and inner wings to help line everything up ime not sure if the bulkhead will be staying in place yet  as i think ime going to have to cut large chunks out of it and being a brand new panel i dont much fancy that better to use it to align everything then once tacked up remove it and make one to suit
Edited by Wreckitralph1, 02 April 2020 - 03:56 PM.
#194 minimikej
minimikej
  • 346 posts
Posted 06 June 2020 - 03:12 PM
Hi, does that windscreen surround panel come with the inner windscreen boxing plates attached? Specifically, these bits:
http://www.somerford...products_id=144
How was it to fit?
Looking good!
