Budget Rebuild
stumpy75
, Jan 28 2019 07:36 PM
193 replies to this topic
#61
Posted 07 March 2019 - 06:21 PM
Not bad will do a 90 dgree bend not quite as sharp next time but its fine
#62
Posted 07 March 2019 - 06:24 PM
Posted 07 March 2019 - 10:48 PM
Excellent mate, wish I had your metalwork skills. Those panels are better than Hadrian without a expensive press.
#64
Posted 07 March 2019 - 10:58 PM
Thank you mate just trial and error the step could be better but as a first go its not bad the next 1 will be 100% its the little step around 4mm deep bfore the lip the cill welds to thats the pain but i will make a tool for the bender to nail that
#65
Posted 08 March 2019 - 06:15 PM
Finishedwthe pillar and drowned it in primer for the time being still needs welding to the inner strengthener which will be new and fabd by me also offered the flitch panel and trimmed it to suit i will be replacing the whole inner wing in 3 peices that will be welded together and dressed
Posted 08 March 2019 - 06:18 PM
Not a bad fit its loosely bolted on atm
Posted 10 March 2019 - 09:10 PM
Started to get the step in plenty of dressing and profiling the weld to match the corner profile to blend the old to new
Posted 11 March 2019 - 10:43 PM
That's coming along nicely
#69
Posted 12 March 2019 - 10:15 AM
So houston we have a problem when i got this shell it had already been got at there was no outer cill no door step and a rotten pillar so today i have offered a lightweight door and it doesnt fit ime wondering wether the shell had sagged on this sid
Plan is to put a brace bar from the x member up to the windscreen pillar weld at the x member and door opening box section braces fit the door and wedge choc into an acceptable door gap position and then weld to the windscreem pillar check and make and fit a new inner pillar (the peice insidewith the holes)
#70
Posted 12 March 2019 - 08:31 PM
Busy day today
Posted 12 March 2019 - 08:35 PM
Again
Made an inner pillar and a boxing flitch towget some strength into the A post pinched unashamedly from the project binky
Posted 13 March 2019 - 09:12 AM
Brilliant work !
#73
Posted 13 March 2019 - 10:09 AM
Last one
use the p/s to make an idetical piece for the drivers side bfore i weld them in
Posted 13 March 2019 - 07:07 PM
Pics
Posted 07 May 2019 - 11:48 AM
So ive been working away for a while had a mate do a bit and he kinda ruined the lip on the A pillar no drama ime goin to deseam it (properly) ive already 70% done the p/s including a 1.2mm steel strip down the inside of the windscreen pillar
As a backing for a nice fat weld its at least as strong as original without a doubt
