pics
Budget Rebuild
#121
Posted 09 November 2019 - 06:12 PM
#122
Posted 09 November 2019 - 06:15 PM
themess that came out
Posted 09 November 2019 - 06:25 PM
brilliant work mate glad your rescuing another tired but now really solid looking mini
#124
Posted 09 November 2019 - 06:50 PM
thank you very much trying my best to make it as good as i can with the tools and skills i have [limited] lol
#125
Posted 11 November 2019 - 05:05 PM
did a little bit more today started cleaning up the heel board ready to offr up the floor pan it had been patched and is shot the outer 8 inches have had it and the lower 30mm right across so a new panel will be fitted but i will get the floor in place using the original first
i may make the new panel yet we shall see
ime thinking of making beefed up inner cill stiffeners with a folded U section with a closing fold on the heelboard end that will have the subframe mounting bolt holes in and threaded bosses using the heel board and bolt holes as my guide after looking at the original stiffener that came out theres hardly anything to it damn sure i can improve on that and it will be welded to the base of the b past
when i then fit the new heel board panel the bolt holes for the subframe are already in place welded ect and the heel board can then be welded as well
hope that makes sense if not tough will have to wait till i get it done and take a few pics
Posted 11 November 2019 - 05:08 PM
again
Posted 11 November 2019 - 05:31 PM
drawn by a 3 year old
Posted 11 November 2019 - 07:06 PM
jees that's rotted to buggery good luck with sorting it
#129
Posted 11 November 2019 - 07:18 PM
yes its a great candidate for rust in peices lol
#130
Posted 12 November 2019 - 12:05 PM
just placed the order with bulmotif spares for the heel board i didnt realise that as i had used a later floor the heel board is also slightly different on the left hand side to compensateso ordered a correct item 85 pound including delivery at this rate every single panel in this shell will be new all thats left is the boot floor back panel rear 1/4s and roof and the boot and quarters and possibly the roof are being changed too
this is definitely not what the project started as but when changing large panels seems stupid not to change the next for a new one if its shot and i dont want to build a panel from 3 or four seperate peices as i dont get much time to work on it and although ime confident of making a good repair panel for the heelboard without issue its the time involved thats the problem where as if i buy a ready made panel its just a case of fit and weld this spot welder is going to have a kicking me thinks
Edited by wreckitralph, 12 November 2019 - 03:05 PM.
#131
Posted 12 November 2019 - 03:13 PM
so managed to get an hour this afternoon and i decided to clean up the mating faces of the toe board the inner face of the door steps and the bottom of the B posts before spraying zinc rich primer
first thing i noticed was how thin the metal of the B post is ive always thought it was quite a sturdy panel but its only around 0.9 mm thick i would have thought this would have been a bit sturdier in terms of gauge of steel used maybe the same as the toe board and bulkhead x member could be a reason why the mini diesnt seem to fair very well in side impact collisions
the second thing and this is quite alarming on the toe board i removed the two square reinforcing plates where the lower front subframe mounts locate as i will be fitting my own
and there was already rust between the two panels bare metal on bare metal
Edited by wreckitralph, 12 November 2019 - 03:16 PM.
#132
Posted 12 November 2019 - 05:18 PM
hes only gone and put the bloody floor in after cleeaning back all the edges and primering i though may as well offer it up as to this point i wansnt sure wether the toe board/bulkhead was in the right position i only had a tape to go by theres always that doubt in the back of the mind its not welded but its in seems to line up very well with nice tight joins ime buzzing this represents a huge milestone for me i have questioned myself on many occasions as to wether ime doing the right thing have i wasted ££££££££££££££ on new panels and nothing is linig up bulkhead out of place ect well the answer is no
the floor is staying put now dont want to mess around with it i will be buggered if ime taking it back out managed to get it in by myself with no drama helps having the body tub suspended from the garage roof with ratchet straps
Edited by wreckitralph, 12 November 2019 - 05:25 PM.
#133
Posted 12 November 2019 - 06:21 PM
a few pics
Posted 12 November 2019 - 06:34 PM
it roughly against the heel board it will be having a new panel within the next few days altho the tunnel is in the correct place i left the box section in to help with that previously had braced the floor with them
Posted 14 November 2019 - 03:21 PM
got the heel board today perfect timing really as the floor is in with tec screws tunnel looks like a porcupine atm lifted the tub up higher with 4x4 posts under the car the with of my shed its not very wide 9 foot so there is only 2 ft either side of the car so not ideal to work on it especially changing floors ect now the the mini is sat on beams that are tied into the actual frame work of the shed it can be ushed fully over to the left or right depending what side ime working on and gives me double the space ive had up until now it also means i can go inside the car to weld being the floor is supported
