Wheeler Dealer Mini
9 replies to this topic
#1 Woolfie 640
Woolfie 640
  • 52 posts
  • Local Club: Mini Moke club
Posted 02 February 2019 - 11:13 AM
Just started on quest the mini upgrade from 10 years ago . A mini for £700 with a full year mot. That's the good old days.
#2 Cooperman
  • 23,567 posts
Posted 02 February 2019 - 10:05 PM
They bodged up two Minis over the years. The first was a real bodge-job and on the second they wrapped it in vinyl and trapped all the rust in.
#3 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 02 February 2019 - 10:15 PM
I often wonder how the vinyl wrapped one they did looks now. Think they auctioned it off at one of the mini 50th events.
#4 Mr.greenPullover
Mr.greenPullover
  • 63 posts
Posted 02 February 2019 - 10:45 PM
Seen L2B 2015...
#5 Archived3
Archived3
  • Archived
  • 99 posts
Posted 02 February 2019 - 11:22 PM
Edited by Mrplastic, 17 March 2019 - 10:37 AM.
#6 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 02 February 2019 - 11:29 PM
1/2 an A panel on the first one!!
#7 Cooperman
  • 23,567 posts
Posted 02 February 2019 - 11:54 PM
I do remember that, but I have to say that I have also done a 1/2 A-panel in the past when the rest of it was perfect and there was just some rust at the bottom. That was on a Mk.1 which was very rust free with otherwise excellent paintwork. I cut the outer just above the lower hinge, joggled the edge of the replacement panel to suit the old panel, welded it all in, gave it a couple of coats of high-build spray putty and it was fine. The lower hinge fitting was fine and needed no work.
I thought it was a 'proper' repair just like any other 'patch repair'. However, I would normally change the entire A-panel as they are usually very rusty including the door supports on the inner wings.
That Mini on Wheeler Dealers even had its boot lid handle fitted 90 degrees out. It was vertical.
#8 Woolfie 640
Woolfie 640
  • 52 posts
Posted 05 February 2019 - 01:31 AM
Number plate no longer recognised by DVLA
#9 parkibob
parkibob
  • 13 posts
Posted 06 February 2019 - 05:55 PM
I remember bidding on the Vinyl wrapped mini back in the day, or at least my lad did, we ended up being filmed making the bid and thankfully was outbid as there were some corners that were not necessarily taken in the right manner with it.
Doesn't look to have aged well in the photo from 2015
#10 ministar
ministar
  • 835 posts
Posted 31 October 2023 - 08:32 PM
I know it’s a massive thread revival but the wheeler dealers mini is back on the road. It was on quest tonight and check MOT check said it’s back on the road 24th September 2023!
Wonder where it is now and what it looks like…
