Anyone got any photos of a genuine mount (peardrop) fixed to the front of the front subframe? Just looking for a reference image. Thanks. Ben
Front Subframe Peardrop Mount
Posted 02 February 2019 - 03:36 PM
Posted 02 February 2019 - 05:54 PM
they can only go one way.
what are you not sure about?
Posted 02 February 2019 - 06:03 PM
I've looked for several images and drawings and they all seem to contradict each other!
Posted 02 February 2019 - 06:12 PM
cant there is only one way and it is the same for all cars. seriously they are one of the easiest parts to change. your Haynes manual shows it clearly.
Posted 02 February 2019 - 07:16 PM
Straight off Minispares
and that may be a cause of confusion as it is pictures 180 degrees out in relation to the subframe.
In that case i shall remove the post then Nick, dont click on the link in the reply folks.
Posted 02 February 2019 - 07:17 PM
The pear shaped flat metal section fits against the front panel with the bolt through the top and the locating pin at the bottom sticking into the hole in the front panel.
The flat round section goes against the front subframe.
If you look at it on the car it can only go one way.
Posted 02 February 2019 - 07:26 PM
to be honest i would say the OP has not actually looked at the car yet as it is one of the easiest jobs and when you start you see there is only one way it can go.
Posted 02 February 2019 - 08:02 PM
I only have the subframe. The shell is at the restorers. I was looking at the drawings on Mini Spares and Somerford's so you can see my confusion if they show the incorrect orientation hence why I was looking for a simple photograph. So what holds it to the subframe? 3/8" bolts through the centre of the circular pad? Or in my case on the Mpi the 2 towing eyes?
Posted 02 February 2019 - 08:15 PM
Yes the bolts hold the peardrop to the subframe, I always thought they were 5/16 but maybe not?
Just a note, these mounts need to be fitted to the car first and then the subframe offered up to the car.
Posted 02 February 2019 - 08:23 PM
yes looking at a part suppliers pages will not help they are not a manual.
if you dont have a Haynes Workshop manual please get one.
