Subframe Mounts ?
Posted 03 February 2019 - 11:51 AM
It’s for a 98 cooper sportspack and I’m after comfort, quietness and something that’ll last!!
Rear subframe I’m thinking the complete poly set from Minispares this looks good in purple!
The front ? I’ve no idea
Any advice really appreciated
Posted 03 February 2019 - 11:54 AM
Posted 03 February 2019 - 11:55 AM
Hi I’m in the process of ordereing subframe mounts but not sure what’s best to get ?
If you're after comfort and quietness, all original rubbers from minispares. Rear subframe I'd do the same, otherwise you face drumming from the boot panel.
Posted 03 February 2019 - 11:56 AM
Just to add I’ve looked at the solid front subframe setup but I’ve my concerns about spacing the subframe for the new front end, are the solid ones a direct replacement? As the look chunky!
You have to space the rubber mounts too..
Posted 03 February 2019 - 01:27 PM
Edited by leepol83, 03 February 2019 - 01:27 PM.
Posted 03 February 2019 - 01:39 PM
Posted 03 February 2019 - 01:42 PM
No spacers needed unless something is out of shape.
Yeh.. Every shell that left rover ;)
Posted 03 February 2019 - 01:43 PM
Right ok 👌🏻 I removed the original mounts there where no spacers on there will I still need to space the new ones if so how much?
When you fit it all back, you may not need them, but always keeping in mind that the Shell's weren't exactly precisely made!
Posted 03 February 2019 - 02:16 PM
Then
Any recommendations on the standard rubber mounts ?
Posted 03 February 2019 - 04:05 PM
Posted 03 February 2019 - 04:30 PM
Cheers really appreciate it
Posted 03 February 2019 - 05:38 PM
Ok I’ll go with the advice recieved, all original mounts throughout then from Minispares
and pay your TMF+ subs and use the discount.
