Ginge The Mpi Engine Bay Refresh
8 replies to this topic
#1 Chris M
Chris M
  • 167 posts
Posted 03 February 2019 - 06:08 PM
After owning my 1998 MPI named Ginge now for about 18 months & my first Mini 've for about 26 years,I thought it was time I got to know it better, fix some oil leaks & freshen up the engine bay.
Heres how I've been getting on.
#2 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 03 February 2019 - 06:17 PM
Great work looks good under there. Look forward to more updates. I want to do my spi bay eventually but looks very busy compared to a carb mini.
#3 Chris M
Chris M
  • 167 posts
Posted 03 February 2019 - 08:20 PM
Yes the engine bay is solid requires a little repair & sorting out the rust on the bulkhead. Then a full repaint of the engine bay before the engine goes back in.
#4 jamesquintin
jamesquintin
  • 1,017 posts
Posted 04 February 2019 - 09:21 AM
I can recomend the sound bulkhead foam from Minispares:
http://minispares.co.../ETD101580.aspx
I also have the small square foam cut out that goes behind the fuel pipes on the bulkhead if you want one..?
Q
#5 Chris M
Chris M
  • 167 posts
Posted 06 February 2019 - 09:30 PM
Thanks James. I was thining of leaving the bulkhead cover off & going for the clean look.
#6 Chris M
Chris M
  • 167 posts
Posted 06 February 2019 - 09:37 PM
Started to strip the engine apart to check the condition inside. Nice & clen inside.
I don't have an engine stand so I used a couple of planks of wood & made my own!
#7 Chris M
Chris M
  • 167 posts
Posted 13 February 2019 - 09:17 PM
I decided to give the head bit of a clean up, so I thought i'd give it a grit blast. The results are amazing!
I covered all the holes up with gaffer tape & was carefull.
#8 Chris M
Chris M
  • 167 posts
Posted 27 February 2019 - 09:57 PM
Bit of an update. Been busy cleaning the engine & buying parts!
Decided the pressure wash the engine block, gave it a good dry out & then oiled the bores & oil ways etc.
Then gave the block a coat of High temperature Volcanic paint to match the car that I had mixed up. Well pleased with  the results so far!
Attached File  IMG_1524.JPG   49.44K   2 downloads
#9 Chris M
Chris M
  • 167 posts
Posted 10 March 2019 - 07:00 PM
I've decided to give Ginge a little more power. I had this little package arrive. The parts look great.
So i decided on a Swiftune cam & adjustable duplex chain kit.
Also I bought a used ported & big vlave head, also a mainiflow exhaust to help the gases escape a little quicker.
