1St Gear Loss
4 replies to this topic
#1 MiniPlayground
MiniPlayground
    Starting My Mini Up
  • 2 posts
Posted 03 February 2019 - 11:07 PM
Hi,
First time poster here, I just received my Mini from Japan a week ago.  I have run into an interesting problem, I cannot get the car into 1st gear.  The car will go into 2nd, 3rd, 4th without issue but when I attempt to go into first and release the clutch it will not engage the gear.  If I push the shifter with all my strength and release the clutch and get some engagement.  I have checked the roll pins and the shifter ball and everything seems to be moving properly and nothing is out of place.  Any ideas as to what I have going on?
#2 Moke Spider
Moke Spider
  • 8,248 posts
Posted 04 February 2019 - 02:39 AM
I'm inclined to think it will be external from the Gearbox.
I'd suggest removing the roll pin from the selector, checking you can select all gears from there (a No. 1 Phillips Driver works for doing this) and while disconnected, having a feel of how the shifter moves through it's range.
Carpet is a common culprit here.
#3 MiniPlayground
MiniPlayground
    Starting My Mini Up
  • 2 posts
Posted 05 February 2019 - 01:40 AM
I checked to see if carpet or anything else was binding it up and it doesn't appear to be.  Here is a photo with the selector cover removed, the selector is in 1st gear.  Does it seem like it is in the correct place? I am looking at the space between the back of the housing and the ball fitting with the pins.
https://lh3.googleus...=w2562-h1922-no
This is a photo of the transmission end:
Thanks for any help.
#4 Retroman
Retroman
  • 852 posts
  • Local Club: CDMC
Posted 06 February 2019 - 09:51 AM
Have a look at the slot / pin on the gear lever swivel ball I suspect the slot to be worn...
#5 viz139
viz139
  • 103 posts
  • Local Club: Irish Mini Owners Club
Posted 06 February 2019 - 07:31 PM
Check for wear and movement  at the bolt above the roll pin on the top rod.
Mini Spares
