Fitting Yellow Tag Master Cylinder To Remove Servo
Posted 04 February 2019 - 01:59 PM
Posted 04 February 2019 - 04:29 PM
The swapping lines refers to changing from the earlier black tag master to yellow tag
Edited by mini_matt_106, 04 February 2019 - 04:29 PM.
Posted 04 February 2019 - 05:26 PM
Posted 04 February 2019 - 05:39 PM
Any wide pedal pre servo pedal will work and considering you are probably invalidating your insurance of at least massively increasing the premium you may as well fit an MS72 or equivalent type valve and bin the FAM7821.........he lights the blue touch paper and stands back :)
On a serious note, what makes you wish to change a great master cylinder/ servo combo going for a lesser part...
Posted 04 February 2019 - 06:54 PM
I totally agree with absx2, You could have serious insurance problems
Posted 04 February 2019 - 09:45 PM
Retro minis do a kit to delete the FAMwtf valve and use the inertia valve for the rear line
Posted 04 February 2019 - 09:54 PM
Still not original - are there any modifications to the vehicle ? - Yes - I swapped it for a **** brake set up !
