Edited by tomBERTfrancis, 04 February 2019 - 08:24 PM.
Posted 04 February 2019 - 08:22 PM
Posted 04 February 2019 - 08:28 PM
buzzing is normally lack of fuel.
might need the filter cleaning. see the hex end there is a filter under there. but stop the fuel before removing it or the pump, also does not look like it is mounted on the rubbers. not good.
Posted 04 February 2019 - 08:51 PM
Posted 05 February 2019 - 02:39 AM
Are you 100% sure the pump is getting power? do you have a 12V test lamp (https://www.ebay.co....tm/331676618490)?
Posted 05 February 2019 - 08:14 AM
Posted 05 February 2019 - 09:02 AM
Posted 05 February 2019 - 09:34 AM
Posted 05 February 2019 - 10:12 AM
Give it a few sharp taps with the handle of a screw driver, always works on my Minor.
Posted 05 February 2019 - 04:14 PM
First of all test the power supply with a Multi-meter. You should have around 12.5 volts with just the ignition on. Check the earth connection as well and clean the earth point.
To confirm the polarity, check which terminal of the battery the earth is on. Very early Minis were positive earth, but that is very rare now as even the older cars will have been converted to negative earth.
If you have power, remove the outlet pipe, put a catch bowl under the outlet pipe and get someone to switch it on for a couple of seconds. If no fuel comes out it is the pump. It could be the filter, but just clamp off the inlet pipe, remove the pump and check the filter.
If the pump is FUBAR, you would do well to change it for a FACET pump, (or, for ultimate reliability, two FACET pumps fitted in parallel). You can fit a FACET in the same place, although you may need to make up a bracket. Alternatively the pump can be bolted through the rear seat base panel with the anti-vibration mountings as supplied in the FACET kit.
It is a simple job.
Posted 06 February 2019 - 09:36 AM
Posted 06 February 2019 - 09:40 AM
Thanks for the detailed reply I will certainly give this a go over the weekend where would I find the earth for the fuel pump?
depends how it was fitted. normally just the body of the pump. but as that is attached to a rubber mounted part they could be a cable earthing the subframe to the body. but as you say it is buzzing it has an earth and it is getting power.
like I said a buzzing is lack of fuel.
if the tank is full and there is not a pool of fuel under the car the pump is being starved of fuel. check the filter.
Posted 06 February 2019 - 12:24 PM
Posted 06 February 2019 - 06:49 PM
I understood that he was not greeted by the usual buzzing, which indicates no power to the pump, a bad earth or a duff pump. Please correct me if I am wrong.
It's easy to check which so long as you have a multi-meter, and no classic Mini owner should be without one of those.
Posted 06 February 2019 - 06:54 PM
