You may also need a soft clamp to clamp the fuel pipe whilst removing the pump, assuming it needs moving.
If you have some mole grips, just get a short length of broom-handle, say 1" long, cut it in half along the centre-line and use that in the mole grips to clamp the pipe without risking splitting it. When the delivery, i.e. outlet, pipe is removed some small amount of petrol will drain back, but it'll soon stop. Just be careful with petrol and ensure that there can be no sparks.
If you need a pump the Mini Spares Part Number is SS502 together with:
FPA905 Rubber Mount Kit x1
FPA906 Pre pump filter union x1
FPA903 Union x1
The pump comes with an earth wire with a ring terminal on the end.
Everyone will tell me I am wrong, but I don't use the rubber mounting kit on my twin-FACET installaton. I just bolt the pumps solidly to the seat base panel. They have been on there for a long time with no problems.
