Kit comprises of:
- Garrett T3 turbo & manifold in known good working condition
- AvonBar oil feed pipe
- Complete custom injection manifold + throttle body & TPS + 3 bar MAP sensor
- 2x NEW Bosch Green Giant injectors
- Microsquirt ECU + EDIS module (not in photo)
- Ford coil pack, bracket & leads
- large selection of intercooler pipework & BOV
- Renault 5 Turbo intercooler
- Air filter
- Idle air valve
There are a few bits that you'll need: a trigger wheel and sensor, coolant temp sensor, a few connectors and a Microsquirt connector/loom (Mine is so heavily integrated into the car loom its impossible to remove now) - I can let you know where to get these from.
You'll also need a high-pressure fuel system & regulator - I can take you through this too.
£1000
(collection, DE73 area)
May consider PX for mini bits.
