i have a mini 998, i have swapped the head for a cooper head and also fitted a stage 1 kit, ( inlet,exhaust and carb spring and needle).
i know i need to set the carb up to make it run properly but i have to put my foot to the floor to start the engine or it will not start.
once the engine starts it revs up and i have to switch it off.
i have the su hs6 carb.
is there a way to set the carb up without the engine being warm as i obviously cant run th engine at the moment.
what do i need to adjust to make it run?
thanks
Edited by Beardy-guesty, 07 February 2019 - 11:25 AM.
