Engine Steady Bar (Top) Info
8 replies to this topic
#1 Sprok
Sprok
  • 133 posts
Posted 07 February 2019 - 12:30 PM
Just a quick one. Im rebuilding a 96 SPI and am fitting the top steady bar but i cant remember if theres a washer or spacer between the bush and the block? My logic would suggest there should be but my old one seemed to bolt straight against the block ? Is that right ?
Thanks Jon
#2 nicklouse
  • 12,306 posts
Posted 07 February 2019 - 12:37 PM
nothing there on the later cars.
#3 cal844
cal844
  • 6,557 posts
  • Local Club: www.scottishmini.net
Posted 07 February 2019 - 05:55 PM
There is occasionally a thick washer, iirc 5mm. It is beneficial to fit one just incase the bolt snaps in the block.
#4 Arthy
Arthy
  • 100 posts
Posted 07 February 2019 - 06:16 PM
There was a thick washer on my 94' Sprite if that helps!
#5 Sprok
Sprok
  • 133 posts
Posted 11 February 2019 - 05:16 PM
Thankyou. Think ill fit one !!
#6 nicklouse
  • 12,306 posts
Posted 11 February 2019 - 06:45 PM
why all the spacers were deleted from 1971.
if you really want to fit one make it a long one that uses both holes and gives a good base for the rubber.
#7 Moke Spider
Moke Spider
  • 8,927 posts
Posted 11 February 2019 - 07:10 PM
The rubber does just overhang a little one of the freeze plugs, by a small amount.
Yes, I make and fit a 5 mm plate here that goes under both bolts. Then if the Steady Bolt should break, there's a chance it won't be a complete trauma to remove it.
This bolt should only ever be a Grade 5 Tensile and so higher so that it has some flexibility. High Grades don't like bending and they crack & break.
#8 Sprok
Sprok
  • 133 posts
Posted 12 February 2019 - 09:36 AM
I was concerned as the silicone bush sits against the block. If it wont perish then ill just leave it?
#9 nicklouse
  • 12,306 posts
Posted 12 February 2019 - 10:50 AM
adding a spacer will not change the conditions for the bush. it will still get just as hot.
Mini Spares
