...silly question...
Have the wheel locating lugs been ground off from around the hub nut?
Yes.
Posted 10 February 2019 - 07:24 AM
Posted 10 February 2019 - 07:25 AM
Posted 13 February 2019 - 05:29 PM
Posted 13 February 2019 - 07:44 PM
Assuming you haven't piqued their interest for the wrong reasons, i'd like to think you should be OK
Posted 14 February 2019 - 10:22 AM
I think the law states ... "When viewed from above no tread must be visible."
Posted 14 February 2019 - 10:44 AM
Posted 14 February 2019 - 11:25 AM
common misconception,
the rule is if you hold a straight edge against the wheel the projected line must be inside the arch, there is also an angle stated for this rule, somthing like 60degrees from vertical each way.
Posted 14 February 2019 - 04:56 PM
That's what it is out here in the colonies and has been for a long time, though there have been some over sights over the years.
When the MKI Cooper S was released, it had no flares fitted, but the South Australian Authorities wouldn't registered them, so flares were fitted, initially by the South Australian dealers. When our MKII Copper S (and all subsequent Minis with 4.5" wide wheels or wider) they all had Arch Extensions fitted at the factory.
