Would there be any performance gains on swapping my Sprite ECU with a Cooper ECU?
Swapping Ecu's......
SW_SCOTTY
, Feb 10 2019 12:48 PM
3 replies to this topic
Posted 10 February 2019 - 12:48 PM
Posted 11 February 2019 - 11:00 AM
The other difference in the two is the the Cooper has a different cam. I was wondering if a SW5-i cam with the Cooper ECU would make much difference?
Posted 11 February 2019 - 12:02 PM
The compression ratio was lower for the Sprite too.
I don't know if you'd get any benefit by just changing the ECU and nothing else.
Posted 19 February 2019 - 08:35 PM
For straight forward bolt-on mods for an SPI without removing the engine, If you go for a modified cylinder head with same compression ratio as a Cooper, 1.5 roller rockers, K&N air filter and a good quality LCB manifold with a 1.75" RC40 (or similar)exhaust system you should notice quite a difference.
If you then fit the Cooper ECU this will accommodate more for the fueling and ignition for the above mods than your current ECU.
By fitting a Cooper ECU on its own without the above mods, I don't think you'll get a great deal from it
Edited by neal, 19 February 2019 - 08:37 PM.
