Making Welds Look Nice !
Posted 10 February 2019 - 08:20 PM
Posted 10 February 2019 - 08:25 PM
Posted 10 February 2019 - 08:30 PM
Posted 10 February 2019 - 08:36 PM
Use Imgur to post pictures on here. The welds if they have fully penetrated can be knocked back flush but be careful not to go too far.
Posted 10 February 2019 - 08:38 PM
Posted 10 February 2019 - 08:43 PM
press more reply options.
Capture.JPG 12.67K 0 downloads
select file
Capture.JPG 21.75K 0 downloads
attach file
1.JPG 21.04K 0 downloads
add to post
2.JPG 10.18K 0 downloads
simples
Posted 10 February 2019 - 08:49 PM
Posted 10 February 2019 - 09:21 PM
Just sussed it im on my computer now
Edited by leepol83, 10 February 2019 - 09:38 PM.
Posted 10 February 2019 - 09:44 PM
Now when i knock back welds i use a flapper disc or grinder followed by coarse and fine roloc discs. Those i use in my high speed pneumatic die grinder.
Most of those welds i see there can be carefully knocked back a lot more but you need to target the raised welds only. Be patient its doable.
Posted 10 February 2019 - 09:48 PM
Posted 10 February 2019 - 09:52 PM
We all have to start somewhere. The biggest thing with any weld is its penetration. If you full penetration then knocking back flat on the side you can see will be fine, just be careful like i said to target the weld only. If the metal burns ie darkens then its thin.
Posted 10 February 2019 - 09:59 PM
Posted 10 February 2019 - 10:18 PM
Posted 10 February 2019 - 10:22 PM
Posted 10 February 2019 - 10:29 PM
Once I’ve knocked them back more would you suggest a thin layer of body filler just to smooth it out a little I will obviously seam seal the welds and Gravitex the lot once finished
Depending on what sort of finish you are looking for a very light skim of filler would not hurt and then seam seal and Gravitex or Raptor.
If you want a show finish then the more work you do with the welds the better, meaning less filler work if any.
