Mpi Arch Seals
15 replies to this topic
#1 bdean
bdean
  • Just Joined
  • 102 posts
Posted 11 February 2019 - 02:20 PM
I have a standard MPi Cooper with the standard black plastic arches.
https://www.minispar...sic/GAW117.aspx
From the factory no seals were fitted with these. Seals were added later for sportspack.
I was advised that it may be best to fit the new ones back with seals regardless and they are pretty rough on the reverse.
Will the sportspack seals work with the standard arch?
https://www.minispar...17.aspx|Back to
Or these alternatives:?
http://www.somerford...roducts_id=1726
https://phoenixtrim....30-ep-192-p.asp
#2 Bobbins
Bobbins
  • 1,344 posts
Posted 11 February 2019 - 02:41 PM
My JDM Cooper has seals on the rear arches (but not the front) that look o/e, although everyone tells me there weren’t any ....
#3 buznout
buznout
  • Just Joined
  • 59 posts
Posted 11 February 2019 - 07:14 PM
Mine had the seals in the above post but front and rear. I pulled the flares off while hunting for rust but put them back on with these..
http://www.minispare...00.aspx|Back to
#4 jamesquintin
jamesquintin
  • 1,017 posts
Posted 11 February 2019 - 07:25 PM
Yup, mine had seals on from new too. Just redid mine with new arches from Minispares:
Q
#5 bdean
bdean
  • Just Joined
  • 102 posts
Posted 11 February 2019 - 08:58 PM
Q
Did you reuse your original seals or buy new?
#6 Bobbins
Bobbins
  • 1,344 posts
Posted 11 February 2019 - 09:01 PM
The arch trim on mine isn't really a soft compressible trim like the universal ones, it's quite stiff and maybe even pre-shaped to the arch extensions. Finding more of it might prove to be tricky though!
#7 jamesquintin
jamesquintin
  • 1,017 posts
Posted 11 February 2019 - 09:21 PM
There was a long roll of it with the kit. Not quite the same but does the job
#8 bdean
bdean
  • Just Joined
  • 102 posts
Posted 12 February 2019 - 08:01 AM
Strange. Did you buy the same kit as me? https://www.minispar...ing/GAW117.aspx
Mine only included the two side sill trims.
#9 jamesquintin
jamesquintin
  • 1,017 posts
Posted 12 February 2019 - 08:56 AM
ah, I 'think' I might have bought it seperatly:
https://www.minispar...g/SPL0059.aspx?
Q
#10 bdean
bdean
  • Just Joined
  • 102 posts
Posted 12 February 2019 - 11:29 AM
Q
Makes sense. I think I'll give this one a try:
https://phoenixtrim....lack-194-p.asp
#11 Pops_Guild
Pops_Guild
  • 363 posts
Posted 12 February 2019 - 03:39 PM
Can't remember where I got mine from but it was from one of the ebay listed Mini shops, got a long roll of it. Did a great job.
Found the listing...https://www.ebay.com...h4AAOxyQj9RTECc
Edited by Pops_Guild, 12 February 2019 - 03:43 PM.
#12 Bobbins
Bobbins
  • 1,344 posts
Posted 19 February 2019 - 02:47 PM
I've now found the o/e seals that should be fitted with the standard plastic arch extensions, available from DSN Classics, Rimmers etc ... despite numerous people telling me they don't exist!
Edited by Bobbins, 19 February 2019 - 02:48 PM.
#13 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 19 February 2019 - 03:20 PM
76-A383-FF-2-F81-4-E52-9-DDA-B1-EDD4-B75
#14 Bobbins
Bobbins
  • 1,344 posts
Posted 19 February 2019 - 04:07 PM
Not the same product, that's for the Sportspack arches.
#15 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 19 February 2019 - 04:40 PM
Think you’ll find it is, it’s the same rover part number DFP 100400
If you read the description properly it tells you it’s also used on the non sports pack plastic special arches
Plus you get discount if purchased through minispares
