Oil Pressure Light Confusion
Best Answer jaybeeonline , 03 March 2019 - 01:54 PM
Got myself a GPS133 oil pressure switch and fitted it this morning - all working as it should and another wee job ticked off the list now
J. Go to the full post
8 replies to this topic
#1 jaybeeonline
jaybeeonline
  • 19 posts
Posted 11 February 2019 - 06:20 PM
The oil pressure light on my GTM Rossa with MG Metro engine & box would not illuminate when I turned the ignition on and suspecting a faulty pressure switch, I bought and fitted a replacement; however, I have a weird situation where the oil pressure light still will not light with ignition on only but when I start and run the engine, the light comes on and off - when I turn the engine off and leave the key in ignition on, it won’t light again.
I know the oil pressure switch earths through the engine block but this has confused the life out of me, as it is working backwards - can anyone with a better brain than me advise?
Ta
J.
#2 mini13
mini13
  • 3,811 posts
Posted 11 February 2019 - 06:30 PM
Check the light with the spade disconnected, and also with it grounded to the block. It should light when grounded.
Iirc the metro turbo had an oil pressure switch that worked back to front as it used the oil switch to cut the fuel pump. Could be you have one of those fitted.
Edited by mini13, 11 February 2019 - 06:31 PM.
#3 nicklouse
  • 19,067 posts
Posted 11 February 2019 - 06:36 PM
a link to the switch you bought would be good as well.
i would also be checking the wiring to the lamp.
#4 Spider
  • 15,877 posts
Posted 11 February 2019 - 07:01 PM
As the other guys have said, while most switches are normally closed with no pressure, there are also some that are normally open on no pressure.
You can change the Switch or fit a relay.
#5 jaybeeonline
jaybeeonline
  • 19 posts
Posted 12 February 2019 - 07:00 AM
The switch I bought was as below;
https://www.ebay.co....872.m2749.l2649
J.
#6 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 12 February 2019 - 05:05 PM
Moss list Mini oil pressure switch as GPS133 ... but I wouldn't have thought that the GPS192 worked differently ... unless that one is for the non-A-series engines fitted to that range of cars ..
#7 nicklouse
  • 19,067 posts
Posted 12 February 2019 - 08:42 PM
J.
Ok what dash display do you have in the car? i am guessing a Metro one?
#8 jaybeeonline
jaybeeonline
  • 19 posts
Posted 12 February 2019 - 09:46 PM
J.
Yes, MG Metro binnacle and I had initially thought that the ribbon had failed but all checked out fine after continuity testing.
J
#9 jaybeeonline
jaybeeonline
  • 19 posts
Posted 03 March 2019 - 01:54 PM   Best Answer
J.
