Bench Running An Spi Engine
3 replies to this topic
#1 Sprok
Sprok
  • 135 posts
Posted 13 February 2019 - 09:22 PM
Currently restoring a 96 SPI and realy wanted to bench test the engine beforeI refitted to the car but time constraints meant i hadto install the engine this week.
The car is almost assembled BUT the main loom is away being replicated ! I have a second hand 96 SPI Loom which i was thinking of connectingjust to try and run the engine.
Does anyone know what are the bare bones essential connections i need to mate to make the engine run? Ive no experience with these SPI units but was hoping to get away with the least amount of conections to run the engine ?
Autosparks are estimating 8-10 weeks for my new loom !!!
Thank you
Jon
#2 Sprok
Sprok
  • 135 posts
Posted 16 February 2019 - 12:06 PM
Anyone ?
#3 viz139
viz139
  • 569 posts
  • Local Club: Irish Mini Owners Club
Posted 16 February 2019 - 08:09 PM
Just to get the engine started you will need.
ECU
Relay box
Alarm to bypass mobilizer
Crank sensor for timing
Coil
Injector for fuel
Fuel pump and inertia switch
Throtle stepper motor to control idle
Ignition Key to power it all.
Limp home mode should take care of temerature and oxygen sensors
#4 Sprok
Sprok
  • 135 posts
Posted 17 February 2019 - 06:49 PM
Lovely thanks
