Lighting Up Dash Switches & Internal Light Delay....and One More
7 replies to this topic
#1 dangerousdowning
dangerousdowning
  • 182 posts
Posted 14 February 2019 - 11:13 AM
Has anyone come up with a method to illuminate the lower dash rail switches, when the headlights are on?
Also, has anyone found an off-the-shelf product that delays the internal light going off, after you close the door - like on a modern car
The last one has just reminded me.....an alarm that indicts you've left the lights on when turning off the ignition - I'm always doing that.
UPDATE: OK, so I've now seen this, which solves two of the questions http://www.minispare...ATION AND LIG..
But can anyone confirm how lights them up? or maybe share a photo of it installed and illuminating the switches.
The its just if anyone has a solution for the internal light delay?
Luke
Edited by dangerousdowning, 14 February 2019 - 11:25 AM.
#2 nicklouse
  • 12,512 posts
Posted 14 February 2019 - 11:31 AM
mine were self illuminating but they took the lighting out on the later ones.
#3 Biggles1957
Biggles1957
  • 20 posts
Posted 14 February 2019 - 12:00 PM
I did my old Morris traveller (which has similar switches on a little panel) using a small strip LED type light...
#4 Ethel
  • 22,926 posts
Posted 14 February 2019 - 02:50 PM
If it's Mk4 onwards (circa '76) it'll have Lucas Delta switches, They have bulbs inside that should light when you turn the sidelights on - I think the Minispares kit utilises these adding resistance to dim them so they made brighter when switched on. You can still get an illuminated side & headlight switch, BL superseded it with an unlit switch because they were prone to melting, you won't have that problem if you run your headlights via relays.
You can get  timer units in standard relay packaging, lots of cars had them, but probably done via an ecu on the latest models. That or find a suitable capacitor.
An Arduino could be a cheaper and more sophisticated way to do the lot.
#5 dangerousdowning
dangerousdowning
  • 182 posts
Posted 14 February 2019 - 03:41 PM
found this to delay, then dim the internal light, but seems a bit pricey just for that job
https://www.moss-eur...er-modules.html
#6 toromod
toromod
  • 13 posts
Posted 14 February 2019 - 05:21 PM
There might be something in Car Builder Solutions??
#7 hhhh
hhhh
  • 422 posts
Posted 14 February 2019 - 07:36 PM
Add a capacitor in parallel with the interior light with a current limiting resistor in series with it.
#8 Ethel
  • 22,926 posts
Posted 15 February 2019 - 11:21 AM
It'd make sense to go led for that approach.
plenty of cheapo Chinese timer modules on fleabay too.
Mini Spares
