Bearing Race Stuck On Cv Joint Shaft
Posted 16 February 2019 - 05:06 AM
Posted 16 February 2019 - 06:20 AM
If you are 'in a bind' you can heat the bearing and then hit it with a chisel and hammer - be sure to wear a face shield - however, you'll find the CV itself has worn and will need to be replaced too
Posted 16 February 2019 - 11:12 AM
in the old days i would just get the angle grinder out. and then hit it with a cold chisel.
Posted 19 February 2019 - 02:26 AM
Pulled the CV joint and decided that trying to remove the inner bearing race wasn't the solution. Am in the process of banging away, trying to get the CV joint over the circlip on the driveshaft. There has to be an easier way.
