Hi,
I've just fitted a pancake filter to my HS4 carb. I've noticed an extra hole in the face of it, what is this for? Shouldn't it be a sealed unit apart from sucking through the filter part or am I missing something?
Pancake Filter Question
noeman
, Feb 18 2019 08:41 PM
6 replies to this topic
Posted 18 February 2019 - 08:41 PM
Posted 18 February 2019 - 08:57 PM
There is a dashpot breather drilling in the carb I believe
Posted 19 February 2019 - 03:45 AM
I’m not sure which extra hole you are talking about, but this type has one that connects to the engine breather system via the black elbow
https://minisport.co...-cleaner-ramflo
Posted 19 February 2019 - 07:09 AM
A lot of air filters have a hole for a crankcase breather.
Posted 19 February 2019 - 07:50 AM
Yes Timmy850 that's the one but mine didn't come with a that black elbow to fit in the hole like the one from minisport. I got mine from mini spares;
http://minispares.co...|Back to search
The only breather pipe I have have is from the tappet chest cover to the carb.
So I'm at loss as what to do, i can't leave it with that hole open or filter won't work properly and I don't have that black elbow nor nothing to connect it to.
Any idea's?
Cheers guys
Any idea's?
Cheers guys
Posted 19 February 2019 - 07:56 AM
I’d get a rubber grommet to blank the hole. Any decent parts shop should have them
Posted 19 February 2019 - 08:04 AM
Thank you, after sending that last message I thought about blanking it off using a nut,bolt & washer. But a grommet sounds neater.
