on it
Mpi Not Starting
#16
Posted 27 February 2019 - 01:30 PM
#17
Posted 27 February 2019 - 02:39 PM
does it earth through the 5/16 bolt securing it to the bracket or is there a separate wire going to ground somewhere. When I dismantled the car 4 years ago I do not recall any earth connections bar the ones in the boot and engine strap
#18
Posted 27 February 2019 - 02:48 PM
Also where is the earth point E1 according to the Haynes manual please.
#19
Posted 27 February 2019 - 02:58 PM
Surely if there is no spark and no fuel then it's something to do with the imobiliser ?????
Do you hear the fuel pump spining when you first put the ignition on ?
#20
Posted 27 February 2019 - 03:02 PM
yes and fuel is pumped up the orange tabbed feed pipe to the rail
#21
Posted 27 February 2019 - 03:04 PM
have renewed the batteries in fobs synchronised them and tell tale light goes out.
I will try the alarm now to see if it operates.
#22
Posted 27 February 2019 - 03:28 PM
This is what I did to mine when I was having problems.
Take a 9v battery (PP3 they used to be called) and sent the 9v to each injector with wires etc. you should hear a slight click if it's not stuck closed (mine were)
#23
Posted 27 February 2019 - 03:29 PM
next, are you getting fuel to the green pipe that goes back to the fuel tank ?
#24
Posted 27 February 2019 - 03:42 PM
alarm operates and turns off as per handbook light on dash also as per.
Tried starting no joy. Plug out again no spark no residual petrol on tip.
#25
Posted 27 February 2019 - 03:45 PM
will now try the 9v solution and see if green pipe has petrol return
#26
Posted 27 February 2019 - 04:07 PM
green pipe has fuel return
9v trying asap
#27
Posted 27 February 2019 - 04:19 PM
9v trick tried both injectors click like good uns
#28
Posted 27 February 2019 - 06:02 PM
#29
Posted 27 February 2019 - 06:39 PM
willing to try anything will have a go tomorrow
still no spark though and have now found a loose wire to bonnet switch. This will impact upon the immobiliser surely. will fix tommorrow
#30
Posted 27 February 2019 - 06:50 PM
The earth is sort of on the bulkhead, in the upper left corner.
I'll get a snap tomorrow if you can't find it.
Edit - Have you made sure the ECU plugs are fully home?
Edited by Wiggy, 27 February 2019 - 06:59 PM.
