What was his diagnoses?
Mpi Not Starting
#61
Posted 11 March 2019 - 09:12 AM
#62
Posted 11 March 2019 - 04:23 PM
poor weather here postponed till Tuesday afternoon.
#63
Posted 12 March 2019 - 09:09 PM
Opened car up in readiness for mechanic I now have no ignition light!!!!!!!!!!
Mechanic came, fully charged battery and new batts in fobs resychronised., he shorted starter out and it turned. Fuel gauge now not working and he was a bit non plussed Suspicions are its the immobiliser Weather foul up here so car is going to his workshop undercover for full investigation.
#64
Posted 14 March 2019 - 05:09 PM
Sounds complicated hope you find the solution!! Keep us up to date.
#65
Posted 14 March 2019 - 07:42 PM
Elimination time. Going to systematically replace simple fixes so before car goes off to mechanic have ordered set of siemens relays and an engine relay pack too. Cannot find anywhere the inertia cut off switch MHQ100130 new or used for love nor money. Any ideas
by the way fuel gauge is working! extra 10 litres of unleaded simples!
#66
Posted 15 March 2019 - 12:03 PM
#67
Posted 15 March 2019 - 01:42 PM
As long as you hear the fuel pump on ignition, then the inertia switch is fine
#68
Posted 02 April 2019 - 11:27 AM
New relays and engine management one near servo all still dead no turn over and no dash lights bar sds which goes off as normal. other electrics working ie lights horn wipers etc.
Must be immobiliser or ECU me thinks.
Its being towed off to mechanic tonight for his attention.
#69
Posted 06 April 2019 - 06:25 PM
I think your fault has changed, so you might have more than one issue. If the car turns over (which it did) that eliminates the immobiliser and you said had no spark. That is likely to only be the coil pack or the crank sensor. Now its not turning over that will be a different issue and could be linked to the immobiliser but why would that just stop working? Lets hope the mechanic knows MPi's well otherwise they may make it worse! Good luck
#70
Posted 14 April 2019 - 10:37 AM
Its a runner!!!!
Continuity checks revealed a loose wire going into multi plug on engine management unit. Remade connection started first time after 4 years!!!
Drove it home 3 miles head gasket now suspect one on order simple fix. MOT after that.
Thanks for all your assistance.
One for admin how can I post pictures please?
#71
Posted 23 April 2019 - 07:08 AM
head sorted mot Thursday
How do I regulate the idle speed which seems to settle out at 1500 rpm
#72
Posted 23 April 2019 - 09:48 AM
Check all the vacuum lines and any gaskets you've removed for air leaks
#73
Posted 23 April 2019 - 02:54 PM
will do although the only two removed in the head gasket replacement, were servo feed and manifold. Manifold one renewed as a matter of course but will check seating of servo pipe and rubber pipes to throttle body later.
Thank you
#74
Posted 24 April 2019 - 07:24 PM
cleaned the idle valve full of soot!! Also blanked off the servo hole problem still persists.
#75
Posted 28 May 2019 - 07:21 PM
ok have renewed manifold plug in servo point and problem still persists car settles out at around 2000 rpm. Also now have overheating problem with steam from rad core. Fan works if put 12v through it, Have ordered new one and new temp sensor. Is there any way of testing the idle valve?
Have had to cancel two MOT appointments getting rather fedup!!
