1293 Rebuild
#31
Posted 04 May 2019 - 07:41 PM
Transfer case breather, timing mark cover and clutch housing bolt set. Yum!
Also a K&N breather filter for the transfer case.
#34
Posted 06 June 2019 - 09:40 PM
If you want a high polish on that Wok you'll have to start with a coarse wet and dry to get the deep marks out - that one does seem quite bad, might be easier to look out for a better one as I don't think they're expensive.
#35
Posted 07 June 2019 - 12:36 PM
Hi John,
I think i'm going to paint it now as it's taken a lot of work so far just to get it to that point, and that was with 400 grit wet and dry!
I've got some black wrinkle paint for my rocker cover so will see how that turns out and may use that or just some gloss black on the crank and flywheel housings...
I've got some MOWOG/BMC green for the engine block and head so thinking a limited overall colour pallette of MOWOG/BMC green and black with polished/silver anodised and red accents should look good. I've been looking in the engine styling section recently for some good inspiration.
Yours is looking great by the way!
Edited by ajperry, 07 June 2019 - 12:36 PM.
#36
Posted 07 June 2019 - 01:09 PM
Thanks, it's obviously a matter of personal preference but I agree that a limited palette is best - some engine bays are an explosion of mis-matched colours that give me a headache! I prefer to use different finishes of the same colour highlighted by alloy and chrome with perhaps one item in a complementary bright colour as a highlight.
Personally I'd suggest doing the whole engine either black or green rather than half and half and limiting a different colour to the rocker cover. Whatever you choose it should reflect you as you're the one whose got to live with it!
Keep up the good work.
#37
Posted 07 June 2019 - 08:49 PM
So, as it’s a 1380, I can’t bore it out any further so they have suggested to get the block sleeved to 1330, which I am happy to do as I’d rather keep this block and have it sorted properly. ...
To get to 1380cc the bores have to be offset .
I’m no expert but because of this I don’t think it’s possible to sleeve a block once it has been taken out to 1380cc
Sure somebody more experienced than me will advise you about this before you spend any more time and money with this block.
#38
Posted 07 June 2019 - 09:32 PM
Edit: after some searching it seems it shouldn’t be a problem to get the machine shop to sleeve from 1380.
Edited by ajperry, 07 June 2019 - 09:54 PM.
#39
Posted 09 June 2019 - 04:38 PM
As I’ve decided to get the machine shop to acid dip both when I get the work done I thought I’d just get the pressure washer out and blast the block clear of all leftover media. Worked out well and while I was doing it a ran some wet and dry over the gasket faces to clean them up a bit.
Happy enough but still peeved. Pics of the head ready and block post clean with WD40 misted over the top to stop the surface rust getting terrible.
Also got my wrinkle paint through during the week so couldn’t wait to spray up the rocker cover. Cleaned it all up and then followed the instructions on the can.
Cleaned up:
First coat with the cap area and cover bolt holes taped:
Used a hairdryer to get the wrinkle started and now will leave it for a few days to fully cure. Photos don’t do the finish justice so I’ll get some better ones once it’s fully set.
#40
Posted 10 June 2019 - 10:36 AM
#41
Posted 10 June 2019 - 11:35 AM
re: engine colour, do you have a car for this engine yet? Reason I ask is that the engine colour changed over the years depending on what model Mini you have.
#42
Posted 10 June 2019 - 06:04 PM
John I think I’ll see how it looks with just the polished cap and cover bolts and take a poll! Haha
Curley, no car at the moment. I really wanted to get started on something I could learn a lot in and the engines always interested me more than bodywork. So bought the engine to work on first as that’s all funds would allow. As soon as I’ve added to my savings this year and, fingers crossed, get a decent Christmas bonus, I’d hope to have a half-decent car early next year. Ideally a runner so I can use it before I make the transplant, but my main criteria is to look for something that’s got bodywork in good condition, minimal tinworm. I’ll be taking my magnet for viewings! ?
#43
Posted 10 June 2019 - 06:34 PM
To do it properly you’ll have to remove all plugs to ensure passages are clear.
I’m not so familiar with the “geography” of mini blocks .. you may need to drill / tap and plug if there are any blind end passages.
Any media left in there is almost sure to cause a seizure.
Edited by Fastorq, 10 June 2019 - 06:36 PM.
#44
Posted 10 June 2019 - 08:47 PM
Be very , very , careful that you clean all the media out of the passages particularly in the block.
Thanks buddy I’m not confident I’ve got absolutely all of it all out so it’ll be the first thing I tell the machine shop and hopefully they can flush it out or what ever needs to happen. Rather leave that to the professionals, as you say it could be catastrophic!
#45
Posted 10 June 2019 - 09:25 PM
I flushed it out submerged in baths of petrol ... the bead could be seen settling in the bottom of the plastic tub after every flush.
I did it numerous times and then when no more bead was showing assembled the engine.
It started , revved it up a few times then the crank/rods seized solid .
