1275 Metro Engine Project
452 replies to this topic
#46 ACDodd
ACDodd
  • Mini Docs
  • 2,654 posts
Posted 11 April 2019 - 11:50 AM
Yes and yes.
Ac
#47 JonnyAlpha
JonnyAlpha
  • 2,744 posts
  • Local Club: Exmoor Minis
Posted 11 April 2019 - 01:15 PM
Yes and yes.
Ac
Ok but just for my education, why are we aiming for a lower CR? Even if I fit the MG Metro CAM?
#48 ACDodd
ACDodd
  • Mini Docs
  • 2,654 posts
Posted 11 April 2019 - 03:48 PM
Because the fuel is worse than when the original engine was designed.
Ac
#49 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 11 April 2019 - 05:42 PM
Ac
I thought that might be the case. Thanks
#50 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 11 April 2019 - 05:43 PM
Next job - clean the block inside and out, no one around here seems to have the facilities to do a full dip.
#51 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 03 June 2019 - 08:57 PM
Ok,
So this is going to be a long slow engine rebuild, but do it right, do it once.
I am going to concentrate on the short engine first.
Block is nearly ready for the rebore, last bit of cleaning up needed and I am probably going to soda blast it if I can get my setup working :-)
I am about to order the pistons but as soon as the rebore is done I need to do the dry build to get the measurements for the block re-facing / skimming.
Dry-Build Process
Is the Dry-Build be done before the Crankshaft is re-ground/polished? And then obviously using the original bearings? What about the Big End Bearings can you do the drybuild with the old bearings?
If the Dry-Build needs to be done after the Crank has been Ground / Polished how do we know what Centre Maini and Main bearings? to get do they come in different sizes depending on the Crank work?
New Pistons / Honing
DryBuild is done with new pistons I guess otherwise it would be pointless, however do you fit the piston rings and if so should the block be honed before or after?
Once the DryBuild is done and the Block is re-faced, I guess the Pistons and Crank can be fitted and Torqued down but what's the best way to keep it rust free until the Head and Gearbox are bolted on?
Oil Galleries
I have removed the Core plugs but not the Oil Gallery plugs yet, I am about to do that to ensure all the crud is gone.
In the Bill Sollis "Ultimate Mini Engine" DVD he recommend threaded Oil Gallery Plugs - any comments on whether I need / should do this?
Sorry for the dumb questions.
Edited by JonnyAlpha, 03 June 2019 - 09:00 PM.
#52 gazza82
gazza82
  • 2,916 posts
  • Local Club: TMF+
Posted 03 June 2019 - 10:01 PM
To keep my part built block rust free it is liberally coated in engine rebuild grease and wrapped in clingfilm.
#53 Cooperman
  • 23,036 posts
Posted 04 June 2019 - 01:59 PM
The 'dry-', or 'trial-build' is done with the crankshaft re-ground or micro-polishes as appropriate and with the new bearings of the correct sizes.
Some of us use 'Plastigauge' to check the bearing running clearance of the main and big-end bearings. Also check the crankshaft end float and correct this as necessary with different thickness thrust bearings.
After the trial-build you strip it all back down and have the block deck machined if necessary so that the tops of the pistons come 0.005" down from block deck level at TDC.
You don't need threaded oil gallery plugs unless the engine is going to be stripped and cleaned out regularly as on a full-on competition car.
To keep it all clean after the short engine is built, I lightly spray it with WD40 and cover it up with an old towel.
The key to good engine building is to keep everything absolutely clean at all times.
#54 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 06 June 2019 - 08:27 PM
What about the waterways? I have done a pretty good job of cleaning them but how to stop them rusting?
#55 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 08 June 2019 - 01:24 PM
And can anyone link any recommended wire brushes that I could put in a drill to get into the knooks and crannies of the oil galleries and waterways?
#56 ryomini
ryomini
  • 583 posts
Posted 11 June 2019 - 02:36 AM
Johnny where are you at now ?  All sounded pretty good so far.
#57 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 11 June 2019 - 07:19 PM
Thanks Cooperman, can you expand on how to check the main and bug end clearances? And linking back to my original question, do we hone the bores before the trial build?
When doing the trial build does the crank need to be Torqued down?
#58 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 11 June 2019 - 07:55 PM
Slowy, slowly, nearly finished cleaned the block:
Went from this:
Here it is after a few days in my Citric Acid solution:
To this:
And few ancillaries after citric acid and a clean up:
And here it is before I removed it from the donor car :-)
#59 Cooperman
  • 23,036 posts
Posted 11 June 2019 - 07:56 PM
When doing the trial build, the bores should be honed so that the piston ring gaps can be checked together with the piston fit in the bores.
I normally torque the main and big-end caps down to 80% of the final figure with the new bearings fitted and check for good smooth rotation. If the crank has been re-ground I measure the journals and ensure that they are within tolerance. If the crank has just been micro-polished measure and, if at bottom limit, use Plasti-Gauge to check the bearing clearances. Normally just accurate measuring very accurately will be sufficient.
#60 JonnyAlpha
JonnyAlpha
  • 2,744 posts
Posted 13 June 2019 - 10:33 AM
So for the Trial and Main Engine Build, there appears to be so much discussion on which Lube to use.
Should I use:
RedLine
or
Torco
I also have 5 Litres of Millers 20W50, which I could use instead.
Ref the RedLine - I noticed this is Synthetic and the future oil going in will be Mineral, isn't it bad to mix the two? What is the Torco stuff, Mineral or Synthetic?
Oh and when it comes to the Cam, do I need a different CamLube such as this one?
