Top Arm Length
3 replies to this topic
#1 Shooter63
Shooter63
  • 174 posts
Posted 06 March 2019 - 09:20 PM
Long storey short, I'm just in the middle of buying a mk1 mini which is wet and I want to dry it out, I know I can use the subbies but need to change the rear trailing arms etc, it's the front arms, I know they will be ok but I did here that hydro top arms are slightly shorter meaning I gain a bit less positive camber, a trick the appendix K guys use, can anybody confirm this or not.
Shooter
#2 nicklouse
  • 11,546 posts
Posted 06 March 2019 - 09:25 PM
they are the same length and are most likely from the same casting. the difference is the position of the drilling for the knuckle.
#3 Shooter63
Shooter63
  • 174 posts
Posted 06 March 2019 - 09:28 PM
Yup just found it on the net,thanks
Shooter
#4 nicklouse
  • 11,546 posts
Posted 06 March 2019 - 11:02 PM
but they do stiffen the spring rate up and you need to drill out the shock mount hole in the arm.
Mini Spares
