Vauxhall Redtop Cooling System
engine
4 replies to this topic
#1 WeekendWarrior16
WeekendWarrior16
    Starting My Mini Up
  • 1 posts
Posted 07 March 2019 - 03:11 AM
Gents, in an effort to reduce the cutting required, am planning on using aluminum a-series radiator with electric fan(10").
Question: On a redtop, would that radiator suffice? Second thought would be to add a second rad in series(there are air to water heat exchangers with .75" inlet/outlet which is... possibly... close enough to the 1" openings on the radiator i plan to use for it to work).
How crazy am i?
#2 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 07 March 2019 - 10:04 AM
I don't think the a series radiator has enough capacity (system capacity is 3.5 litres
Edited by cal844, 07 March 2019 - 10:06 AM.
#3 imack
imack
  • 1,873 posts
Posted 07 March 2019 - 01:01 PM
Friend of mine is running an astra gte 16v alloy rad in his. He had to get the top hose inlet modified to suit the standard thermostat housing. Not sure what size fan hes running but it is tight.
#4 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 07 March 2019 - 01:38 PM
No particular issue with running multiple radiators though. My Boxster does this as standard
#5 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 07 March 2019 - 08:27 PM
Yes I agree there is no issue running more than one radiator, if it's good enough for the German manufacturers it will do here ?
