Flywheel Lightening
33 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,749 posts
  • Local Club: Exmoor Minis
Posted 07 March 2019 - 06:18 PM
OK so another post regarding my potential Metro 1275 - 1293 refurb.
On my shopping list I have a Minispares lightened Flywheel at £133.82, but could I get a machine shop to lighten my own Flywheel and save some money?
Seems to be a few people on here planning or doing 1275's at the mo :-)
#2 nicklouse
  • 19,066 posts
Posted 07 March 2019 - 06:45 PM
sure but thy need to know what they are doing and know how much is safe to remove before you get to a state where it can grenade. standard flywheels are cast iron. good lightened ones are steel. same goes for the backplate you want steel.
Vizard has the "safe" info in his books.
i would just replace.
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 07 March 2019 - 07:13 PM
I do a lot;
https://youtu.be/ay14axlnHXA
Ontop of that price you also need to add in balancing.
Ac
#4 Cooperman
  • 23,569 posts
Posted 07 March 2019 - 07:59 PM
The Mini Spares lightweight flywheel is really for competition.
For road use, it is easy to lighten the standard Verto flywheel, which you probably have. The MS lightweight version is for the pre-Verto flywheel/clutch.
#5 Fastorq
Fastorq
  • 186 posts
Posted 07 March 2019 - 08:40 PM
I do a lot;
Ac
Hiya
Watched your video and it seems straightforward.
Are you targeting a specific weight ?
Are all your cuts .0040”
DavidR
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 07 March 2019 - 11:25 PM
0.040" is the biggest my lathe can take and be safe.
Ac
#7 dotmatrix
dotmatrix
  • 441 posts
Posted 08 March 2019 - 10:11 AM
Nice video. If nothing Else is changed on an engine what is the effect of a lighter flywheel on the torque? Does the peak move Up the rev Range?
Edited by dotmatrix, 08 March 2019 - 10:12 AM.
#8 Cooperman
  • 23,569 posts
Posted 08 March 2019 - 10:57 AM
Torque is basically determined by the head and cam design. A lighter flywheel will not alter the torque produced. However, a lighter flywheel will reduce the rotational stored energy (basically mass x rotational velocity) making the tick-over less smooth and the engine easier to stall when pulling away from rest.
However, acceleration will be improved as less available power is being used to accelerate the flywheel.
#9 Fastorq
Fastorq
  • 186 posts
Posted 08 March 2019 - 12:20 PM
If I ever manage to get the B&*#@r off I’ll try this
Do you do your own balancing?
Regds
DavidR
#10 Steve220
Steve220
  • 5,144 posts
  • Local Club: BMC
Posted 08 March 2019 - 12:35 PM
I do a lot;
Ac
I could watch that all day!
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 08 March 2019 - 01:14 PM
Frequently balance, and for the trade too.
#12 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 08 March 2019 - 07:24 PM
I have the yellow bible but cannot find any specifics on the Flywheel apart from pg 382/383 which talks about the theory and give the formulae for calculating how much equivalent simulated weight would be removed from the car with every 1lb of weight removed from the Flywheel. I was expecting details of what to remove and from where?
#13 JonnyAlpha
JonnyAlpha
  • 2,749 posts
Posted 08 March 2019 - 08:18 PM
I do a lot;
Ac
Hi;
I found your video before posting the thread, I thought there would be more videos ref Mini Flywheel lightening?
Anyway, when you say you do a lot, do you mean cast iron ones? Is the Metro Flywheel Cast Iron and is it safe to lighten cast iron flywheels?
#14 nicklouse
  • 19,066 posts
Posted 08 March 2019 - 08:28 PM
I do a lot;
Ac
Hi;
it is safe if you know what you are doing like AC does. it is the people who dont know what they are doing that cause problems.
#15 Carlos W
Carlos W
  • 10,115 posts
Posted 08 March 2019 - 10:03 PM
I do a lot;
Ac
Hi;
Spot on
