Flywheel Lightening
33 replies to this topic
#31 imack
imack
  • 2,197 posts
Posted 11 March 2019 - 05:50 PM
As a rough guide....
Depends where the weight is from relative to the crank centre line, the gearing, the weight removed and the weight of the car
The weight from any internal lightening is approx 1:10 in 1st gear
So 1kg off engine internals is approx 10 kg off the car as you go through each gear the 1:10 reduces
There is a formula in DV's book
It has no affect on top speed, but you will get there quicker....
Megalite Fw, alloy spacers, 3 straps, En24 lightened bolts, Alloy Back Plate Ti bolts. Whole set up 4.8 kg
Nice flywheel!
#32 KTS
KTS
  • 2,459 posts
Posted 11 March 2019 - 07:13 PM
Nice flywheel!
..it's hardly a flywheel - more like a pressure plate with ring gear attached!!
#33 Dusky
Dusky
  • 5,322 posts
Posted 11 March 2019 - 07:43 PM
Cant blame anyone looking out the window in physics class, loads of bad physics teachers around, while it is the most beautiful class possible if done right :)
#34 Inno
Inno
  • 138 posts
Posted 12 March 2019 - 01:18 AM
Vizard yellow book page 382, 3rd edition - what is there really sounds logical and proven practically and with formula.....guess no really doubt regarding benefits of lighter components,  just find the right proportion of components for intended use.
Edited by Inno, 12 March 2019 - 01:27 AM.
