Pollution Test Hc Count
12 replies to this topic
#1 dotmatrix
dotmatrix
  • 441 posts
Posted 08 March 2019 - 09:33 AM
What is the normal HC count for a healthy a-series with a correctly timed md266 cam?
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,841 posts
Posted 08 March 2019 - 01:16 PM
About 500 to 600hc's
Ac
#3 dotmatrix
dotmatrix
  • 441 posts
Posted 09 March 2019 - 12:46 AM
Ac
Great. Thanks. Mine was 1600 with low co so i suspect Worn chain and oil rings.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 09 March 2019 - 08:34 PM
Low CO will cause high Hc  reading, do a engine tune and then re test is what I'd do first
Edited by KernowCooper, 09 March 2019 - 08:34 PM.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,841 posts
Posted 10 March 2019 - 08:39 AM
Also too much vacuum advance at idle will cause this. It's not uncommon to reduce the HC count by half, by removing and plugging the carb vacuum line to the dizzy. The long term solution in this case is a ported vac take off mod for your carb.
Ac
#6 unburntfuelinthemorning
  • 2,003 posts
Posted 10 March 2019 - 03:59 PM
Ac
Why is it later SUs seem to have a vacuum take off which gives manifold vacuum so loads of advance at idle speed?
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,841 posts
Posted 10 March 2019 - 04:59 PM
I think it's to do with retarded mechanical advance with the high compression ratios employed in factory engines.
Ac
#8 dotmatrix
dotmatrix
  • 441 posts
Posted 10 March 2019 - 05:40 PM
HC count did not change within Range i adjusted the co
#9 dotmatrix
dotmatrix
  • 441 posts
Posted 10 March 2019 - 05:42 PM
Ac
In what way should the vac takeoff be ported? Havent heard og This before
#10 unburntfuelinthemorning
  • 2,003 posts
Posted 10 March 2019 - 06:18 PM
It should be as shown here:
https://www.britishv...ted-vacuum.html
#11 unburntfuelinthemorning
  • 2,003 posts
Posted 10 March 2019 - 06:23 PM
This might help too:  http://www.theminifo...dvance-fitting/
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 March 2019 - 10:14 PM
This is after a run through the engine tune ? what happens when you take the revs up to 2000rpm
#13 dotmatrix
dotmatrix
  • 441 posts
Posted 12 March 2019 - 10:47 PM
this adjustment of the co value was after a long drive and then I pulled straight into the place where I measured the co. I didn't take the engine up in rpm as I only wanted to adjust the idle co. when that is right the whole rev range is usually right as it has previously been had the needle done on a dyno, but the mixture goes out of tune and the way the engine have been driving lately lead me to believe that it was running too rich again, but it wasn't. but the hc count did seem high (although I dont have a reference for this number because I never looked at it before) which is why I asked the question about causes for high hc count.
