Got to the point that I would like to get an engine start. Cranks over with good oil pressure, but no sign of a spark on No1 plug. Its the carb engine with electronic dizzy. Checked the wiring diagrams post to confirm if I have connected everything correctly and can't see any mention of this set up. I've got the wiring from the 65DM4 connected to the same coil terminals as the harness wires, so white/blacks together and whites together. Static timed to about two degrees BTDC just to get it running. Will then strobe to five degrees at 1500. But with no spark, that just ain't happening right now!
Any pointers as to where/what I should be checking, please?
